Braindumpspdf
Finding the Installing and Configuring Windows Server 2012 exam's dumps is the major problem faced by most IT professionals and students out there. By seeing this need of peoples. We have designed the latest 70-410 exam dumps with the 2018 updates. We strive to ensure that each certification materials package and individual question is authentic. Our 70-410 exam dumps collection is consistently being updated with the latest materials for existing tests, as well as new certifications. The Braindumpspdf contain actual exam dumps featuring multiple choice questions. You can view the sample questions as given below.
http://bit.ly/70-410-dumps
Question No : 1 - Topic 1
You have a server named Server1 that runs Windows Server 2012 R2. Server1 has the
Hyper-V server role installed. On Server1, you create a virtual machine named VM1. VM1
has a legacy network adapter.
You need to assign a specific amount of available network bandwidth to VM1.
What should you do first?
  • A. Remove the legacy network adapter, and then run the Set-VMNetworkAdapter cmdlet.
  • B. Add a second legacy network adapter, and then run the Set-VMNetworkAdopter cmdlet.
  • C. Add a second legacy network adapter, and then configure network adapter teaming.
  • D. Remove the legacy network adapter, and then add a network adapter.
Answer : D
Explanation: A. Set-VMNetworkAdaptercmdlet configures features of the virtual network adapter in a virtual machine or the management operating system B. The legacy network adapter doesnt support bandwidth management C. The legacy network adapter doesnt support bandwidth management D. Add a New network adapter. The legacy network adapter doesnt support bandwidth management.
Question No : 2 - Topic 1
Your network contains an Active Directory forest named contoso.com. The forest contains
a single domain. The domain contains two domain controllers named DC1 and DC2 that
run Windows Server 2012 R2.
The domain contains a user named User1 and a global security group named Group1.
You need to modify the SAM account name of Group1.
Which cmdlet should you run?
  • A. Add-AdPrincipalGroupMembership
  • B. Install-AddsDomainController
  • C. Install-WindowsFeature
  • D. Install-AddsDomain
  • E. Rename-AdObject
  • F. Set AdAccountControl
  • G. Set-AdGroup
  • H. Set-User
Answer : G
Question No : 3 - Topic 1
Your network contains a server named Server1 that runs Windows Server 2012 R2.
Server1 has the Hyper-V server role installed.
Server1 hosts four virtual machines named VM1, VM2, VM3, and VM4.
Server1 is configured as shown in the following table.
You install a network monitoring application on VM2.
You need to ensure that all of the traffic sent to VM3 can be captured on VM2.
What should you configure?
  • A. NUMA topology
  • B. Resource control
  • C. Resource metering
  • D. Virtual Machine Chimney
  • E. The VLAN ID
  • F. Processor Compatibility
  • G. The startup order
  • H. Automatic Start Action
  • I. Integration Services
  • J. Port mirroring K. Single-root I/O virtualization
Answer : J
Explanation: With Hyper-V Virtual Switch port mirroring, you can select the switch ports that are monitored as well as the switch port that receives copies of all the traffic. And since Port mirroring allows the network traffic of a virtual machine to be monitored by copying the traffic and forwarding it to another virtual machine that is configured for monitoring, you should configure port mirroring on VM2. Reference: http://technet.microsoft.com/en-us/library/jj679878.aspx#bkmk_portmirror
With the help of all the reference and the explanations of the answers, get your compiled set from here:
RunePup
I have placed an updated file with the free vce player in the exam section
