Practice Labs / Tools
Discussion in '70-740' started by Markw, Apr 19, 2017.
  1. Markw
    Markw Member
    Apr 19, 2017
    Does anyone know of any practice labs or servers we can use for studying this exam?
    I've got access to Microsoft Azure for 6 months so I can setup a Virtual Server with Server 2016. Wandering if this will be the same or if anyone has any suggestions.
  2. UncleB
    UncleB Member
    Mar 18, 2017
    64
    20
    Just create a new Azure VM (OS family 5) which will create a server 2016 machine - create as many as you need and build your own environment as you go using the free trial period.
    You can get a few hundred $ worth of free azure spend using the Visual Studio Dev route which is all free:
    You even get free access to Pluralsight training for a few months.
  3. mukhwa
    mukhwa Member
    Jan 15, 2017
    get vmware workstation download server 2016 ISO from microsoft and you are good to go
  • enya
    enya Well-Known Member
    Contributor Member
    254
    thanx
