PassLeader 70-744 Dumps with VCE and PDF (Apr/2018 Updated)
Discussion in 'General Certification' started by Gabrijela Jović, Feb 22, 2017.
  1. Gabrijela Jović
    Sep 1, 2016
    ATTENTION PLEASE!!! THE 70-744 EXAM UPDATED RECENTLY (Apr/2018) WITH MANY NEW QUESTIONS!!!
    You can get the newest 70-744 questions in the
    #18 of this topic!!!
    Hi! The new PassLeader 70-744 dumps (2017 version) now are available on passleader.com, here are part of 70-744 exam questions (FYI):
    Note: This question is part of a series of question that use the same or similar answer choices. An answer choice may be correct for more than one question in the series. Each question is Independent of the other questions in this series. Information and details provided in a question apply only to that question. Your network contains an Active Directory domain named contoso.com. The domain contains a file server named Server1 that runs Windows Server 2016. Server1 has a volume named Volume1. Dynamic Access Control is configured. A resource property named Property1 was created in the domain. You need to ensure that Property1 is set to a value of Big for all of the files in Volume1 that are larger than 10 MB. Which tool should you use?
    A. File Explorer
    B. Shared Folders
    C. Server Manager
    D. Disk Management
    E. Storage Explorer
    F. Computer Management
    G. System Configuration
    H. File Server Resource Manager (FSRM)
    Answer: F
    Your network contains an Active Directory domain named contoso.com. You have an organizational unit (OU) named Secure that contains all servers. You install Microsoft Security Compliance Manager (SCM) 4.0 on a server named Server1. You need to export the SCM Pnnt Server Secunty baseline and to deploy the baseline to a server named Server2. What should you do? To answer, select the appropnate options in the answer area.
    [​IMG]
    [​IMG]
    Note: This question is part of a series of questions that present the same scenario. Each question In the series contains a unique solution that might meet the stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution. After you answer a question in this section, you will NOT be able to return to It. As a result, these questions will not appear in the review screen. Your network contains an Active Directory forest named contoso.com. All servers run Windows Server 2016. The forest contains 2,000 client computers that run Windows 10. All client computers are deployed (rom a customized Windows image. You need to deploy 10 Pnvileged Access Workstations (PAWs). The solution must ensure that administrators can access several client applications used by all users. Solution: You deploy 10 physical computers and configure each wie as a virtualization host. You deploy the operating system on each host by using the customized Windows image. On each host you create a guest virtual machine and configure the virtual machine as a PAW. Does this meet the goal?
    Your network contains an Active Directory forest named contoso.com. The forest functional level is Windows Server 2012. All servers run Windows Server 2016. You create a new bastion forest named admin.contoso.com. The forest functional level of admin.contoso.com is Windows Server 2012 R2. You need to implement a Privileged Access Management (PAM) solution. Which two actions should you perform? Each correct answer presents part of the solution.
    A. Raise the forest functional level of admm.contoso.com.
    B. Deploy Microsoft Identify Management (MIM) 2016 to admin.contoso.com.
    C. Configure contoso.com to trust admin.contoso.com.
    D. Deploy Microsoft Identity Management (MIM) 2016 to contoso.com.
    E. Raise the forest functional level of contoso.com.
    F. Configure admin.contoso.com to trust contoso.com.
    Answer: CF
    Your network contains an Active Directory domain named conioso.com. The domain contains 1,000 client computers that run Windows 8.1 and 1,000 client computers that run Windows 10. You deploy a Windows Server Update Services (WSUS) server. You create a computer group tor each organizational unit (OU) that contains client computers. You configure all of the client computers to receive updates from WSUS. You discover that all of the client computers appear m the Unassigned Computers computer group in the Update Services console. You need to ensure that the client computers are added automatically to the computer group that corresponds to the location of the computer account in Active Directory. Which two actions should you perform? Each correct answer presents part of the solution.
    A. From Group Policy objects (GPOs), configure the Enable client-side targeting setting.
    B. From the Update Services console, configure the Computers option.
    C. From Active Directory Users and Computers, create a domain local distribution group for each WSUS computer group.
    D. From Active Directory Users and Computers, modify the flags attnbute of each OU.
    E. From the Update Services console, run the WSUS Server Configuration Wizard.
    Note: This question Is part of a series of questions that use the same or similar answer choices. An answer choice may be correct for more than one question in the series. Each question is Independent of the other questions in this series. Information and details provided in a question apply only to that question. Your network contains an Active Directory domain named contoso.com. The domain contains a server named Server1 that runs Windows Server 2016. Server1 has a shared folder named Share1. You need to encrypt the contents of Share1. Which tool should you use?
    A. File Explorer
    B. Shared Folders
    C. Server Manager
    D. Disk Management
    E. Storage Explorer
    Answer: H
    Note: This question is part of a series of questions that use the same scenario. For your convenience, the scenario is repeated in each question. Each question presents a different goal and answer choices, but the text of the scenario is exactly the same in each question in this series.
    - Start of repeated scenario
    Your network contains an Active Directory domain named contoso.com. The functional level of the forest and the domain is Windows Server 2008 R2. The domain contains the servers configured as shown in the following table.
    [​IMG]
    All servers run Windows Server 2016. All client computers run Windows 10. You have an organizational unit (OU) named Marketing that contains the computers in the marketing department. You have an OU named Finance that contains the computers in the finance department. You have an OU named AppServers that contains application servers. A Group Policy object (GPO) named GP1 is linked to the Marketing OU. A GPO named GP2 is linked to the AppServers OU. You install Windows Defender on Nano1.
    - End of repeated scenario
    You need to ensure that you can deploy a shielded virtual machine to Server4. Which server role should you deploy?
    A. Hyper-V
    B. Device Health Attestation
    C. Network Controller
    D. Host Guardian Service
    Get the newest 70-744 VCE dumps here:
    Download more PassLeader 70-744 PDF dumps from Google Drive for free here:
    #1 Gabrijela Jović, Feb 22, 2017
    nlefier and Ferencz Farkas like this.
  2. Isabel Lind
    Isabel Lind Member
    Sep 26, 2016
    Hi!
    Do you have that full version PassLeader 70-744 dumps (PDF or VCE, VCE is the best)???
    I am going to take my 70-744 exam next week, please kindly share.
    e-mail:
    Thanks!!!
    Steve Pike likes this.
  3. Ferencz Farkas
    Aug 23, 2016
    35
    Thanks for sharing PassLeader 70-744 dumps!
    Please send both PassLeader 70-744 dumps and 70-743 dumps to me. (erdmlgoheety@outlook.com)
    Thanks again!!!
  4. Adnan Jamil
    Adnan Jamil Member
    Oct 30, 2016
    Just passed 70-744 exam yesterday (26/Feb/2017)!
    Learning all questions from Premium PassLeader 70-744 dumps!
    Thanks for sharing the newest PL 70-744 exam questions. Great!
    How much you got question in exam?
  • roby
    roby Member
    Mar 7, 2017
    is it possible to have a full version for this exam?
    Thank you.
  • ilovepsppsp
    ilovepsppsp Member
    Mar 6, 2017
    Thank you.
  • Yobalder
    Yobalder Member
    Dec 1, 2016
    26
    Thank you very much! :)
  • Filosk
    Filosk Member
    Jan 22, 2016
    Cannot recall which dumps is this, but it is worth for checking out. Aiotestking never fails and the date of the questions is 24 January 2017.
    The problem is there are no comments to provide information if this is reliable dump for passing.
  • pentiumfour
    pentiumfour Member
    Mar 22, 2017
    the ones on aiotestking are wrong, those are from 98-367 Security Fundamentals. The passleader.com one is close but there's a lot of wrong questions.
  • Filosk
    Filosk Member
    Jan 22, 2016
    Thanks for the heads up. It turns out we are still waiting for the best version of the dump.
  • walls
    walls Member
    Mar 25, 2017
    99
    21
    email
    Thank.
  • pentiumfour
    pentiumfour Member
    Mar 22, 2017
    new vce available now!
    lets review this! it looks like is the same passleader one
  • pentiumfour
    pentiumfour Member
    Mar 22, 2017
    Hi!
    e-mail:
    Thanks!!!
    how was the test?
  • JasonK
    JasonK Member
    Apr 6, 2017
    Hi could I please get the 70-744 passleader, email is
  • UncleB
    UncleB Member
    Mar 18, 2017
    64
    21
    Scroll up to the first post in this thread and click on the Google Drive link - the files are all there and can be downloaded by right-clicking on them.
  • Filosk
    Filosk Member
    Jan 22, 2016
    Can you pass the exam with those files from the Google Drive? Anyone?
  • pentiumfour
    pentiumfour Member
    Mar 22, 2017
    Anyone?
  • Gabrijela Jović
    Sep 1, 2016
    The new 70-744 dumps (Apr/2018 Updated) now are available, here are part of 70-744 exam questions (FYI):
    NEW QUESTION 145
    You have a Hyper-V host named Hyperv1 that has a virtual machine named FS1. FS1 is a file server that contains sensitive data. You need to secure FS1 to meet the following requirements:
    - Prevent console access to FS1.
    - Prevent data from being extracted from the VHDX file of FS1.
    Which two actions should you perform? (Each correct answer presents part of the solution. Choose two.)
    A. Enable BitLocker Drive Encryption (BitLocker) for all the volumes on FS1.
    B. Disable the virtualization extensions for FS1.
    C. Disable all the Hyper-V integration services for FS1.
    D. On Hyperv1, enable BitLocker Drive Encryption (BitLocker) for the drive that contains the VHDX file for FS1.
    E. Enable shielding for FS1.
    NEW QUESTION 146
    Your network contains an Active Directory domain named contoso.com. The domain contains 1,000 client computers that run either Windows 8.1 or Windows 10. You have a Windows Server Update Services (WSUS) deployment. All client computers receive updates from WSUS. You deploy a new WSUS server named WSUS2. You need to configure all of the client computers that run Windows 10 to send WSUS reporting data to WSUS2. What should you configure?
    A. an approval rule
    B. a computer group
    C. a Group Policy object (GPO)
    D. a synchronization rule
    NEW QUESTION 147
    You have a server named Server1 that runs Windows Server 2016. You need to identify the default action for the inbound traffic when Server1 connects to the domain. Which cmdlet should you use?
    A. Get-NetIPSecRule
    B. Get-NetFirewallRule
    C. Get-NetFirewallProfile
    D. Get-NetFirewallSetting
    E. Get-NetFirewallPortFilter
    F. Get-NetFirewallAddressFilter
    G. Get-NetFirewallApplicationFilter
    NEW QUESTION 148
    Your network contains an Active Directory domain named contoso.com. The domain contains a file server named Server1 that runs Windows Server 2016. Server1 has a shared folder named Share1. You plan to create a subfolder in Share1 for each domain user. You need to limit each user to using 100 MB of data in their respective subfolder. The solution must enable the users to be notified when they use 80 percent of the available space in the subfolder. Which tool should you use?
    A. File Explorer
    B. Shared Folders
    C. Server Manager
    D. Disk Management
    E. Storage Explorer
    Answer: H
    NEW QUESTION 149
    Your network contains an Active Directory domain named contoso.com. The domain contains 100 servers. You deploy the Local Administrator Password Solution (LAPS) to the network. You need to view the password of the local administrator of a server named Server5. Which tool should you use?
    A. Active Directory Users and Computers
    B. Computer Management
    C. Accounts from the Settings app
    D. Server Manager
    Use "Active Directory Users and Computers" to view the attribute value of "ms-MCS-adminpwd" of the Server5 computer account.
    NEW QUESTION 150
    Your network contains an Active Directory domain named contoso.com. The domain contains a server named Server1 that runs Windows Server 2016. You need to prevent NTLM authentication on Server1.
    Solution: From Windows PowerShell, you run the New-ADAuthenticationPolicy cmdlet.
    ADDS Authentication Policy does not provide ability to prevent the use of NTLM authentication.
    NEW QUESTION 151
    You have a server named Server1 that runs Windows Server 2016. You need to install Security Compliance Manager (SCM) 4.0 on Server1. What should you install on Server1 first?
    A. the .NET Framework 3.5 Features feature
    B. the Active Directory Rights Management Services server role
    C. the Remote Server Administration Tools feature
    D. the Group Policy Management feature
    NEW QUESTION 152
    Your network contains an Active Directory domain named contoso.com. The domain contains 100 servers. You deploy the Local Administrator Password Solution (LAPS) to the network. You discover that the members of a group named FinanceAdministrators can view the password of the local Administrator accounts on the servers in an organizational unit (OU) named FinanceServers. You need to prevent the FinanceAdministrators members from viewing the local administrators' passwords on the servers in FinanceServers. Which permission should you remove from FinanceAdministrators?
    A. List contents
    B. All extended rights
    C. Read all properties
    D. Read permissions
    Access to the password is granted via the "Control Access" right on the attribute. Control Access is an "Extended Right" in Active Directory, which means if a user has been granted the "All Extended Rights" permission they'll be able to see passwords even if you didn't give them permission.
    NEW QUESTION 153
    NEW QUESTION 159
    You have 10 Hyper-V hosts that run Windows Server 2016. Each Hyper-V host has 8 virtual machines that run a distributed web application named App1. You plan to implement a Software Load Balancing (SLB) solution for client access to App1. You deploy 2 new virtual machines named SLB1 and SLB2. You need to install the required components on the Hyper-V hosts and the new servers for the planned implementation. Which components should you install?
    [​IMG]
    [​IMG]
    NEW QUESTION 160
    You configure Just Enough Administration (JEA). You need to ensure that a non-administrator user can perform the following actions:
    - Restart Internet Information Services (IIS).
    - Restart a custom service named Service1.
    How should you complete the role configuration file?
    [​IMG]
    [​IMG]
    Get the newest PassLeader 70-744 VCE dumps here:
    Download more NEW PassLeader 70-744 PDF dumps from Google Drive here:
    Read the newest PassLeader 70-744 exam questions from this Blog:
  • Andrew william
    Apr 12, 2018
    88
    If you are looking for the Securing Windows Server 2016 Exam valid dumps, then i am suggesting you the dumps from where i prepare my exam Prepare the exam along with job is much difficult especially when you have a night job. Get
    and prepare your exam. They provide accurate and authentic 70-774 Exam Questions. 70-774 dumps is really profitable certification now a day. It opens many jobs opportunities to groom their career. Visit this website today and get 70-774 dumps as It will help you prepare the exam in a better way. So don't be waste your time and money visit now
  • MCSZ
    MCSZ Member
    Jul 20, 2018
    Hello all, what is the best dumps site for 744? Thanks in advance.
    Would appreciate personal comments, not advertising..... :eek:
