[Passed PT0-001] CompTIA PenTest+ PT0-001 Certification dumps
victoriagoze
As an CompTIA certification, it is well known that passing the CompTIA PenTest+ PT0-001 has become a global standard for many successful IT companies. Are you preparing for the PT0-001 Choose Passcert. Passcert PT0-001 Exam will provide you with questions and verified answers that reflect the actual exam. Furthermore, we are constantly updating our CompTIA PenTest+ PT0-001 Certification dumps. Each candidate who decide to take the PT0-001 exam can receive the most reliable and up-to-date information from Passcert.
Share some PenTest+ PT0-001 exam questions and answers below.
Which of the following is the reason why a penetration tester would run the chkconfig --del servicename command at the end of an engagement?
A. To remove the persistence
B. To enable persistence
C. To report persistence
D. To check for persistence
A security analyst was provided with a detailed penetration report, which was performed against the organization’s DMZ environment. It was noted on the report that a finding has a CVSS base score of 100.
Which of the following levels of difficulty would be required to exploit this vulnerability?
A. Very difficult; perimeter systems are usually behind a firewall
B. Somewhat difficult, would require significant processing power to exploit
C. Trivial, little effort is required to exploit this finding
D. Impossible; external hosts are hardened to protect against attacks
Which of the following tools is used to perform a credential brute force attack?
A. Hydra
B. John the Ripper
C. Hashcat
D. Peach
A penetration tester wants to target NETBIOS name service.
Which of the following is the MOST likely command to exploit the NETBIOS name service?
A. arpspoof
B. nmap
C. responder
D. burpsuite
A penetration tester has performed a security assessment for a startup firm. The report lists a total of ten vulnerabilities, with five identified as critical. The client does not have the remediate to immediately remediate all vulnerabilities.
Under such circumstances which of the following would be the BEST suggestion for the client?
A. Apply easy compensating controls for critical vulnerabilities to minimize the risk, and then reprioritize remediation
B. Identify the issues that can be remediated most quickly and address them first.
C. Implement the least impactful of the critical vulnerabilities' remediations first, and then address other critical vulnerabilities
D. Fix the most critical vulnerability first, even if it means fixing the other vulnerabilities may take a very long time.
