Passed It Today 70-341
ismilecu
Passed with 9xx score. 50 Q's in total. 3 Case Studies - 4Q each + 38 other Q's (mixed+D&D) All 3 case studies and 38 Mixed-D&D Q's are exactly as the lead2pass 242q dumps. Good luck to everyone.
Brain_Killer
hi,
Can you share the dump?
Kgumza
hi,Samosni
can you please share the dump you used to prepare for exam
travis_d
This is not entirely true. I passed the exam today scoring high 700. I used the very same premium dump on account of this person's comment. There were at least 10-12 questions I had never seen.
Perhaps he got lucky and each exam runs slightly differently. That being said, I think this dump is at least enough to get you the pass with some cushion.
Ali Naemi
Congratulations!
Passed the 70-341 test last weekend!! Scored 890!!!
Total 52 questions = 5+44+3.
Many new questions (around 8-10 new questions) appeared in my actual 70-341 test.
Case Studies are from the following 6 FYI:
1. Case Study 1: Contoso Ltd.
2. Litware, Inc.
3. A.Datum Corporation
4. Proseware, Inc.
5. Fabrikam, Inc.
6. Trey Research
And, some Drag and Drop questions I remembered FYI:
1. Get-TransportConfig cmdlet: make a shadow copy of the message on another server/3 hours.
2. solution to ensure that users can access their mailbox by using IMAP4: Set-SendConnector cmdlet/Set-IMAPSettings cmdlet/Set-ReceiveConnector cmdlet.
3. add EX2 to DAG2: one-Add EX5 to DAG1; two-Create Mailbox database copies on EX5; 3-On EX2, remove all of the mailbox database copies; 4-Remove EX2 from DAG1; 5-On EX2 install Windows Server 2012 R2 and Exchange Server 2013
Recommend to learn the NEWEST & VALID forbiden 70-341 dumps here:
http://www.microsoftbraindumps.com/category/mcse-exam-collection/mcse-productivity-exam-collection/70-341-dumps
(IT IS THE NEWEST VERSION -- 261 Q&As!!!)
Eleleta Fethawi
The new 2018 version (Sep/2018 Updated) 70-341 dumps now are available, here are part of 70-341 exam questions (FYI):
NEW QUESTION 261
You deploy an Exchange Server 2013 organization to a test network for evaluation. You install the Mailbox server role and the Client Access server role on a server named ex01.contoso.com. You do not perform any other configurations. All of the ports from the Internet to ex01.contoso.com are open. You successfully connect to ex01.contoso.com from the Internet and from the internal network. You need to identify which types of Exchange Server clients will connect successfully to the organization without any further configurations. What should you identify?
A. Internal IMAP clients
B. Internal Microsoft Outlook connections
C. Windows RT devices running the Mail app
D. Android Phones using Activesync
NEW QUESTION 262
Your company has two data centers. The data centers are located in Miami and New York. Five thousand users connect to the New York data center. One thousand users connect to the Miami data center. The data centers connect each other by using a dedicated high-speed WAN link. You plan to deploy two Exchange Server 2013 servers to each data center. You need to recommend a high-availability deployment strategy for the mailbox servers. The solution must ensure site resiliency. What is the best recommendation to achieve the goal? (More than one answer choice may achieve the goal. Select the BEST answer.)
A. Deploy one database availability group (DAG).
Add the servers to the DAG.
Deploy a file share witness to the New York data center.
Deploy an alternate file share witness to the Miami data center.
B. Deploy one database availability group (DAG) to each data center.
Add the servers to their respective DAG.
Deploy a file share witness in Microsoft Azure.
Deploy an alternate file share witness to each data center.
C. Deploy one database availability group (DAG).
Deploy an alternate file share witness to one of the data centers.
D. Deploy one database availability group (DAG) to each data center.
Deploy a file share witness for each DAG to its respective local data center.
Deploy an alternate file share witness to the other data center.
NEW QUESTION 263
You have an Exchange Server 2013 on-premises organization and a Microsoft Office 365 tenant. All mailboxes are hosted on-premises. You need to implement an archiving solution for all users. The solution must ensure that all mailbox content older than 18 months is moved to Personal Archives in Office 365. What should you implement?
A. a retention policy and a retention policy tag (RPT)
B. a retention hold and a retention policy tag (RPT)
C. a retention policy and a personal tag
D. a retention policy and a default policy tag (DPT)
NEW QUESTION 264
You have an Exchange Server 2013 organization. You deploy an anti-spam appliance and you connect the appliance to the Exchange Server organization. You need to disable keyword filtering of email messages that are received from the Internet. Which Windows PowerShell cmdlet should you use?
A. Set-SendConnector
B. Set-ReceiveConnector
C. Set-ContentFilterConfig
D. Set-EdgeSyncServiceConfig
NEW QUESTION 265
Your network contains an Active Directory forest named contoso.com. The forest contains the domain controllers configured as shown in the following table:
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-341-dumps-2651.jpg
You plan to deploy an Exchange Server 2013 organization to the forest. All Exchange Server 2013 servers will be located in the West site. A company policy prevents administrators from logging on to DC2 to perform installations. You need to prepare the Active Directory schema for the planned Exchange Server deployment. You verify that your user account has all the required permissions to achieve the task. The solution must minimize changes to the Active Directory infrastructure. What is the best approach to prepare the schema? (More than one answer choice may achieve the goal. Select the BEST answer.)
A. Log on to DC1 and then run Exchange setup.
B. Move the schema master role to DC3, and then run Exchange setup.
C. Log on to DC3, and then run Exchange setup.
D. Deploy a member server to contoso.com, and then move the server to the West site.
Run adprep.exe from the member server.
NEW QUESTION 266
You have an Exchange Server 2013 organization that contains five servers. The organization contains 5,000 mailboxes. One hundred users plan to leave your company during the next 48 hours to run a new company named Fabrikam, Inc. The mailboxes of the 100 users are in a mailbox database named DB5. The deleted item retention setting for DB5 is two days. You need to implement a solution to meet the following security requirements:
- The 100 users must be prevented from permanently deleting any email messages from their mailbox.
- In 48 hours, you must create a copy of only the email messages that contain the word "Fabrikam".
- The solution must be implemented as quickly as possible.
A. Modify the deleted item retention period for DB5, and then run the New-MailboxSearch cmdlet in 48 hours.
B. Modify the deleted item retention period for the 100 mailboxes, and then run the New-MailboxSearch cmdlet in 48 hours.
C. Modify the deleted item retention period for DB5, and then run the Search-Mailbox cmdlet in 48 hours.
D. Enable Single Item Recovery for the 100 mailboxes, and then run the New-MailboxSearch cmdlet in 48 hours.
Incorrect:
Not E: New-MailboxSearch alone will just create a search. You would need to run the Start-MailboxSearch cmdlet to actually run the search.
NEW QUESTION 267
You have an exchange Server 2013 organization that contains one server. A user named User 1 report that he cannot view several email messages from his mobile device. He confirms that he can view the email messages by using Microsoft Outlook. You need to enable and view the Exchange ActiveSync log for User1. Which two actions should you perform? (Each correct answer presents part of the solution. Choose two.))
A. Run the Get-CasMailbox cmdlet.
B. Modify the TraceSessions.config file.
C. Run the Set-Mailbox cmdlet.
D. Run the Set-CasMailbox cmdlet.
E. Run the Get-MobileDeviceStatistics cmdlet.
NEW QUESTION 268
B. Remove-DeliveryAgentConnector
C. Set-ContentConfig
D. Disable-Service
NEW QUESTION 269
You have an Exchange Server 2010 organization that contains 10 Client Access servers and 20 Mailbox servers. The organization has several throttling policies deployed. You need to identify which throttling policies will be used for different connection scenarios. In the table below identify which throttling policies will be used for each scenario. (NOTE: Make only one selection in each row.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-341-dumps-2691.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-341-dumps-2692.png
NEW QUESTION 270
You have an Exchange Server 2013 organization named contoso.com that contains several servers. The organization contains 3,000 mailboxes. You plan to deploy a hybrid coexistence solution and move 1,000 mailboxes to Exchange Online. You also plan to configure all mail exchanger (MX) records for contoso.com to point to Exchange Online and to enable centralized mail transport. You need to identify how mail will be routed. What should you identify? (To answer, drag the appropriate mail route to the correct option. Each mail route may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.)
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-341-dumps-2701.png
http://www.microsoftbraindumps.com/wp-content/uploads/2018/09/forbiden-70-341-dumps-2702.png
NEW QUESTION 271
Get the newest forbiden 70-341 VCE dumps here: https://www.forbiden.com/70-341.html
Download more NEW forbiden 70-341 PDF dumps from Google Drive here:
https://drive.google.com/open?id=0B-ob6L_QjGLpfjZ2U1ZfVEZvU0ZreTJkNG1xdmxjS0xUYkdHWVMxWFNRVDhOYTlyRzBjOXM
Read the newest forbiden 70-341 exam questions from this Blog:
http://www.microsoftbraindumps.com/?s=70-341
