Pass 70-740!
Discussion in '70-740' started by Braindumpspdf, Feb 19, 2018.
  1. Braindumpspdf
    Braindumpspdf Member
    Feb 15, 2018
    87
    Installation, Storage, and Compute with Windows Server 2016 Exam is the most famous Microsoft certification exam. If you are planning to jump high while taking this course, then you need to prepare yourself for this exam. 70-740 dumps are a very useful way to prepare your MCSA 70-740 exam. With the help of authentic and updated 70-740 exam dumps you can clear your exam in first attempt. We also have introduced the 70-740 exam practice material to take the drill before taking the real Microsoft exam. To download 70-740 exams dumps and further info visit
    Question 1/10 – 70-740 practice test
    You are using Sysprep.exe to prepare a system for imaging. You want to enable end users to customize their Windows operating system, create user accounts, name the computer, and perform other tasks. What sysprep option should you use?
    1. /generalize
    2. /oobe
    3. /audit
    4. /unattend
    Answer: 2
    Explanation: The /oobe option restarts the computer into Windows Welcome mode. Windows Welcome enables end users to customize their Windows operating system, create user accounts, name the computer, and perform other tasks. Any settings in the /oobe system configuration pass in an answer file are processed immediately before Windows Welcome starts.
    Exam Objective: 1.0 Install Windows Servers in Host and Compute Environments
    Question 2/10 – 70-740 practice test
    You purchase a new desktop computer that has four external USB hard drives. You want to create a single volume by using the four USB drives. You want the volume to be expandable, portable, and resilient in the event of failure of an individual USB hard drive. You need to create the required volume. What should you do?
    1. Create a new Storage Space across 4 USB hard drives and set resiliency type to three-way mirror
    2. Create a new spanned volume
    3. Create a new Storage Space across 4 USB hard drives and set resiliency type to parity
    4. Create a new striped volume
    Answer: 3
    Explanation: Storage Spaces can combine multiple hard drives into a single virtual drive. To create a Storage Space, you must connect two or more additional internal or external drives to the computer to create a storage pool. When the drive begins to fill up and nears the physical limit, Windows will display a notification prompting you to add additional physical storage space. Selecting the Parity resiliency type allows Windows to store parity information with the data, thereby protecting you from a single drive failure.
    Exam Objective: 2.0 Implement Storage Solutions
    Question 3/10 – 70-740 practice test
    When Bob logs onto the Data folder, what will his Local and Remote permissions be?
    1. Local would be Full Control, and Remote would be Deny
    2. Local would be Deny, and Remote would be Deny
    3. Local would be Full Control, and Remote would be Change
    4. Local would be Change, and Remote would be Read
    Answer: 1
    Explanation: Permissions are additive among themselves, meaning that you get the highest level of permissions. But when the two permissions meet, the most restrictive set of permissions applies. In this question, the NTFS side would be Full Control (this would be the Local permission), and the Shared permission would be Deny. But when the two permissions meet, the most restrictive, Deny, would apply.
    Question 4/10 – 70-740 practice test
    You deploy a Hyper-V server in an isolated test environment. The test environment is prevented from accessing the Internet. The new server runs the Datacenter edition of Windows Server 2016. You plan to deploy the following guest virtual machines on the server:
    Quantity Operating System Domain Member
    10 Windows Server 2012 R2 Yes
    4 Windows Server 2016 No
    5 Windows Server 2016 Yes
    What activation model will you use for the virtual machines?
    1. Multiple Activation Key (MAK)
    2. Automatic Virtual Machine Activation (AVMA)
    3. Original Equipment Manufacturer (OEM) key
    4. Key Management Service (KMS)
    Answer: 2
    Explanation: Automatic Virtual Machine Activation (AVMA) is a feature that allows administrators to install virtual machines on a properly activated Windows Server 2016 system without the need to manage individual product keys for each virtual machine. When using AVMA, virtual machines are bound to the licensed Hyper-V server as soon as the virtual machine starts.
    Exam Objective: 3.0 Implement Hyper-V
    Question 5/10 – 70-740 practice test
    You are installing Hyper-V on a server core installation of Windows Server 2016. Which of the following commands will you use?
    1. start /w ocsetup Hyper-V
    2. start /w ocsetup microsoft-hyper-v
    3. start /w ocsetup Microsoft-Hyper-V
    4. start /w ocsetup hyper-v
    Answer: 3
    Explanation: Commands are case sensitive, which requires the command “start /w ocsetup Microsoft-Hyper-V” to be used to install Hyper-V on a Server Core computer.
    Question 6/10 – 70-740 practice test
    To put an image into a container, you use the “docker run” command with which one of the following?
    1. The Image ID
    2. The image MAC
    3. The image IP
    4. The image filename
    Answer: 1
    Explanation: To put an image into a container, type “docker images” into PowerShell and get the Image ID. Type “docker run” and the ID number.
    Exam Objective: 4.0 Implement Windows Containers
    Question 7/10 – 70-740 practice test
    You now have a number of different images and wish to add useful common names for the images. Which of the following commands will name your image EagleImage?
    1. docker run -t EagleImage
    2. docker image EagleImage
    3. docker build -t EagleImage
    4. docker name EagleImage
    Answer: 3
    Explanation:To tag an image that you have created, use the -t parameter with the “docker build” command.
    Question 8/10 – 70-740 practice test
    1. Maintenance needs to be performed on an NLB cluster node, but you don’t want to terminate current connections. What should you use?
    2. Evict
    3. Drainstop
    4. Stop
    5. Pause
    Answer: 2
    Explanation: Drainstop is the function that allows the current session to end before stopping the cluster on the node. Evict is used to remove a node completely from a failover cluster. Pause is used to keep resources from failing over to a failover cluster node. Stop will immediately end the cluster service on the NLB cluster node, not allowing the current session to complete.
    Exam Objective: 5.0 Implement High Availability
    Question 9/10 – 70-740 practice test
    What new Windows Server 2016 feature optimizes failover cluster by identifying Hyper-V nodes that are hosting a disproportionate number of VMs and redistributing the VMs to other nodes?
    1. Node equality
    2. Node fairness
    3. Node justice
    4. Node parity
    Explanation: Node fairness is a new failover cluster feature in Windows Server 2016 that helps optimize usage of failover cluster node members. VMs hosted on clustered Hyper-V servers can move from node to node based on system reboots and maintenance operations, resulting in an unbalanced distribution of VMs throughout the cluster. Node fairness attempts to identify Hyper-V nodes that are hosting a disproportionate number of VMs and redistribute VMs to other nodes that are underutilized.
    Question 10/10 – 70-740 practice test
    Which of the following is NOT true about installing WSUS on Server 2016?
    1. WSUS role should be on an Active Directory domain
    2. WSUS cannot be installed with Remote Desktop Services
    3. WSUS should be installed on a domain controller
    4. WSUS can be on a standalone server that is not on the domain
    Answer: 3
    Explanation: The WSUS server shouldn’t be installed on a domain controller. The server on which you install the WSUS role should be a member of an Active Directory domain and cannot run Remote Desktop Services. Although a domain environment is not required, client configuration is much easier if the WSUS server and all the client computers are domain members.
    Exam Objective: 6.0 Maintain and Monitor Server Environments
    Download all these from here:
    or from here:
