[H12-211 English version] HCNA H12-211-ENU dumps - 292q
victoriagoze
There are so many candidates preparing for HCNA H12-211 certification, we have many candidates who has passed HCNA H12-211 exam with high score verrifed Passcert dumps and go further on HCNP filed. If you want to latest HCNA dumps to study and pass in your first attempt, We highly recommended Passcert HCNA H12-211-ENU dumps.
1.An administrator wishes to manage the router in the remote branch office, which method can be used?
A. Telnet
B. FTP
C. Console Connection
D. DHCP
2.An authenticator router has been configured with two domains named "Areal" and "Area2", following which a user is created with the username "huawei" and the password "hello" for authentication.
Which domain does this user belongs to?
A. Areal domain
B. Area2 domain
C. default domain
D. default_admin domain.
3.Users in the network discovered that the efficiency of a file transfer is low. The administrator used wireshark to observe the network and discovered many duplicate frames.
Which statement correctly explains the reason for this?
A. The switch doesn't know the destination and has flooded frames
B. This network needs upgrading to use newer and more efficient switches.
C. The network has loops at the link layer
D. The network has not been segmented using VLANs.
4.On VRP platform, which of the following parameters can be used together with the "ping" command to specify the source address of an echo request message?
A. -a
B. -s
C. -d
D. -n
5.The network administrator creates VLAN 10 and assigns an IP address to VLANIF10.When using the command "display ip interface brief", the administrator finds that VLANIF10 is down.
What should be done to enable VLANIF10?
A. Use the command "undo shutdown" under the interface view for VLANIF10.
B. Assign a physical interface that has either an active of inactive physical state to VLAN 10.
C. Assign only a physical interface that has an active physical state to VLAN 10.
D. Add an interface that has an active physical state and a trunk port associated with VLAN 10.
6.Which of the following regarding Frame Relay DLCI are correct? (Multiple Choice)
A. DLCI is locally significant
B. DLCI is allocated by DTE.
C. The range of DLCI value that can be used is from 16-1007.
D. The same DLCI can be configured on different physical interfaces.
Answer: ACD
7.Refer to the command output.
ip route-static 10.0.12.0 255.255.255.0 192.168.1.1
Which statement is true regarding this command?
A. The configuration represents a static route to the 192.168.1.1 network.
B. The configuration represents a static route to the 10.0.12.0 network
C. The preference value of this configured route is 100.
D. If the router has learned the same destination network via a dynamic routing protocol, the static route will always take precedence.
8.Which of the following authentication methods are supported for Telnet users? (Multiple Choice)
A. Password authentication.
B. AAA local authentication.
C. MD5 authentication.
D. No authentication.
Answer: ABD
9.On an FR network, the DLCI identifies a virtual circuit on an interface. The DLCI must be unique during planning and deployment.
A. TRUE
B. FALSE
10.A company applies for a class C IP address for subnetting, it has eight branches. The largest branch has a subnet and should support at least 14 hosts.
What would be an appropriate subnet mask?
A. 255.255.255.0
B. 255.255.255.128
C. 255.255.255.192
D. 255.255.255.224
henry109
There are such huge numbers of applicants getting ready for HCNA H12-211 accreditation, we have numerous hopefuls who have passed HCNA H12-211 exam with high score checked real exam dumps and go further on HCNP recorded. On the off chance that you need to most recent HCNA dumps to study and go in your first endeavor. I highly recommend real exam dumps H12-211 exam dumps which is highly appreciated by highly top qualified IT experts and highly authenticated. I have also experienced through this exam study material and got A+ grades and besides passing this certification also get a deep understanding of Huawei Network Technology and Device (HCDA-HNTD).
