Harrison Brookes
The new CCDA 200-310 dumps (Nov/2019 Updated) now are available, here are part of 200-310 exam questions (FYI):
NEW QUESTION 696
The network infrastructure of a building is being expanded, which includes switches from multiple vendors connecting back to a traditional Cisco switching infrastructure. Which EtherChannel configuration must be used between the two environments?
A. PAgP auto
B. LACP active
C. LACP on
D. PAgP desirable
NEW QUESTION 697
Which description of the top-down network design approach is true?
A. It begins with an analysis of the organization's requirements at the upper OSI layers.
B. It is used when the application requirements are not available to the network designer.
C. It begins with an analysis of the physical layer of OSI model.
D. It does not consider the OSI Layer model.
NEW QUESTION 698
Which three functions of a wireless LAN controller in an enterprise WLAN are true? (Choose three.)
A. Control traffic over multiple VLANs when an AP is in REAP mode.
B. Control traffic over multiple VLANs when an AP is in H-REAP mode.
C. Control client traffic from and to AP through a CAPWAP tunnel.
D. Control AP over WAN when an AP is in H-REAP mode.
E. Control APs over WAN when an AP is in remote mode.
F. Control client traffic from and to AP through GRE tunnel.
NEW QUESTION 699
You are designing a network that will support the addition of bandwidth as demand increases. Which term correctly describes this requirement?
A. resiliency
B. scalability
C. modularity
D. multitiered
NEW QUESTION 700
An engineer is designing a disaster recovery solution to avoid IP renumbering when bringing up virtual machines in the alternate data center. Which technology is used?
A. Virtual Routing and Forwarding
B. Virtual Device Contexts
C. Overlay Transport Visualization
D. Multicast Routing
NEW QUESTION 701
Which two methods can Cisco routers and switches use to share information between directly connected devices on a regular basis? (Choose two.)
A. CDP
B. LLDP
C. NHRP
D. NetFlow
E. ARP
NEW QUESTION 702
Which two considerations are important when designing an IP address plan? (Choose two.)
A. the type of connected devices
B. the number of locations
C. the name of the locations
D. the number of devices per location
E. the speed of the connected devices
NEW QUESTION 703
Which issue is a possible result of using the bottom-up approach to network design?
A. The designer is unable to draw on previous experience.
B. The network QoS policies might be configured improperly.
C. The resulting design might fail to meet the requirements of the organization.
D. The design process can be extremely time consuming.
NEW QUESTION 704
Which advantage to using route summarization is true?
A. enables efficient peering with other autonomous systems
B. provides an overview of all subnets used across the infrastructure
C. enabled recalculation of the routing table with any update for optimum convergence
D. reduces routing table size and improves convergence
NEW QUESTION 705
An application developer in your company requires a multicast host address for his application and asks for your recommendation. Which two multicast IPs do you recommend? (Choose two.)
A. 240.40.40.40
B. 223.23.23.23
C. 230.30.30.30
D. 211.11.11.11
E. 238.38.38.38
Answer: CE
NEW QUESTION 706
When preparing for a design of an existing network, you identify all the existing information and documentation. Which action do you take next?
A. Run a performance review.
B. Create a new design document.
C. Conduct a network audit.
D. Perform a traffic analysis.
NEW QUESTION 707
Which routing protocol feature do you use when scaling a network?
A. administrative distance
B. neighbor authentication
C. route summarization
D. periodic flooded updates
NEW QUESTION 708
Which layer of the OSI model, when included in the access layer, results in a smaller fault domain?
A. Layer 1
B. Layer 2
C. Layer 3
D. Layer 4
NEW QUESTION 709
An engineer is designing a hierarchical LAN design for an enterprise campus. Drag and drop the function from the left onto the correct layer on the right.
NEW QUESTION 710
An engineer is performing a basic server load balance. Drag and drop the tasks from the left into the correct order on the right.
NEW QUESTION 711
Download more NEW Pass Leader 200-310 PDF dumps from Google Drive here:
Read the newest Pass Leader 200-310 exam questions from this Blog:
To pass Cisco 200-310 exam is no more dream. Now Cisco students don’t need to burn midnight all to pass Cisco 200-310 exam. Just visit Exams4Sale and get material from Cisco 200-310 Expert.Get 35% discount by using promocode 35%OFF. Exams4Sale offers more relevant and upto date material for Cisco exam dumps so the material is 100% accurate that’s why I recommend you this site for your Cisco 200-310 exam on the basic of above mentioned qualities. So light up your lamp of success by visiting the link below:
