SATORUINUI
The new NSE5_FAZ-6.0 dumps (April/2019 Updated) now are available, here are part of NSE5_FAZ-6.0 exam questions (FYI):
You've moved a registered logging device out of one ADOM and into a new ADOM. What happens when you rebuild the new ADOM database?
A. FortiAnalyzer resets the disk quota of the new ADOM to default.
B. FortiAnalyzer migrates archive logs to the new ADOM.
C. FortiAnalyzer migrates analytics logs to the new ADOM.
D. FortiAnalyzer removes logs from the old ADOM.
What is the purpose of employing RAID with FortiAnalyzer?
A. To introduce redundancy to your log data.
B. To provide data separation between ADOMs.
C. To separate analytical and archive data.
D. To back up your logs.
How do you restrict an administrator's access to a subset of your organization's ADOMs?
A. Set the ADOM mode to Advanced.
B. Assign the ADOMs to the administrator’s account.
C. Configure trusted hosts.
D. Assign the default Super_User administrator profile.
What FortiView tool can you use to automatically build a dataset and chart based on a filtered search result?
A. Chart Builder
B. Export to Report Chart
C. Dataset Library
D. Custom View
What must you configure on FortiAnalyzer to upload a FortiAnalyzer report to a supported external server? (Choose two.)
A. SFTP, FTP, or SCP server
B. Mail server
C. Output profile
D. Report scheduling
If you upgrade your FortiAnalyzer firmware, what report elements can be affected?
A. Output profiles
B. Report settings
C. Report scheduling
D. Custom datasets
On FortiAnalyzer, what is a wildcard administrator account?
A. An account that permits access to members of an LDAP group.
B. An account that allows guest access with read-only privileges.
C. An account that requires two-factor authentication.
D. An account that validates against any user account on a FortiAuthenticator.
How can you configure FortiAnalyzer to permit administrator logins from only specific locations?
A. Use static routes
B. Use administrative profiles
C. Use trusted hosts
D. Use secure protocols
Logs are being deleted from one of your ADOMs earlier that the configured setting for archiving in your data policy. What is the most likely problem?
A. The total disk space is insufficient and you need to add other disk.
B. CPU resources are too high.
C. The ADOM disk quota is set too low based on log rates.
D. Logs in that ADOM are being forwarded in real-time to another FortiAnalyzer device.
What FortiGate process caches logs when FortiAnalyzer is not reachable?
A. logfiled
B. sqlplugind
C. oftpd
D. miglogd
Download more NEW Pass Leader NSE5_FAZ-6.0 PDF dumps from Google Drive here:
Read the newest Pass Leader NSE5_FAZ-6.0 exam questions from this Blog:
Smithwell
100% Success Opt Now: https://www.theexamcerts.com/Fortinet/NSE5_FAZ-5.4-pdf-exam-dumps If you want to prepare for NSE5_FAZ-5.4 FortiAnalyzer 5.4 Specialist exam in shortest possible time, with minimum effort but for the most effective result, you can use TheExamCerts Fortinet NSE5_FAZ-5.4 exam dumps. TheExamCerts has a variety of NSE5_FAZ-5.4 Network Security Analyst certification exam braindumps and other exam preparation material which gives you consolidation in the ways of your interest and ease. TheExamCerts delivers Fortinet NSE5_FAZ-5.4 exam dumps which give you detailed and logical coverage of Fortinet NSE5_FAZ-5.4 exam pattern syllabus and provide you with the real NSE5_FAZ-5.4 exam environment as these products are built by IT examiners so you experience the real Fortinet NSE5_FAZ-5.4 exam features in our NSE5_FAZ-5.4 exam products. Try free demo of Fortinet NSE5_FAZ-5.4 exam questions before buy actual dumps questions. Follow this link and get 20% discount offer [Limited Time]: https://www.theexamcerts.com/Fortinet/NSE5_FAZ-5.4-pdf-exam-dumps
xander luis
Recently I pass Exam with 86% score and get NSE5_FAZ-6.0exam certification. I tried several study material for passing NSE5_FAZ-6.0 Exam then I find the actual NSE5_FAZ-6.0exam dumps pdf. It is so lucky for me. Highly recommended to everyone, Thanks.
