70-346 Exam March 2016
Naruc
Microsoft.Mashup.70-346.v2016-03-12.by.Naruc.184q
v3.0
-added question
-corrected one question
Microsoft.Mashup.70-346.v2016-02-23.by.Naruc.183q
v2.5
-corrected a few questions.
Microsoft.Mashup.70-346.v2016-02-14.by.Naruc.183q
v2.4
-added question
-corrected one question.
Microsoft.Mashup.70-346.v2016-02-05.by.Naruc.182q
v2.3
- added questions
Microsoft.Mashup.70-346.v2016-02-04.by.Naruc.165q
v2.2
-updated revision.
-removed duplicate question.
A few questions seem similar in content some have identical answers. If you just memorized the questions you will fail. Microsoft tweaked most of question from this dump, make sure you understand the concept behind the question.
IMPORTANT INFORMATION:
Please consider this Dump as a tool to help and improve lack areas.
Never must be considered as a replacement for the experience and formal study.
Microsoft always update their exams, the accuracy of the information provided here is not warranted
For Internal use only.
If you want to edit this file , try this tutorial
I am no longer updating this file.
VCE file
PDF File
Naruc
well I will update one :))
Question 86 answer is D not E.
Explanation was spot on, but I have choose by mistake the wrong one. If someone has the time will update VCE/PDF files as well
gfernandez
I did exam the past week, passed with + 800
56 questions, about 6/7 were new questions and some else with little variations. You can pass if you read carefully.
One of the new question was some like this:
Q. You have exchange on premises environment with one server in New York and another one in London. You migrate to Office 365 with hybrid deployment. You create a new mailbox. Where will be created the new mailbox?
a\ Random datacenter
b\ You can choose the datacenter
c\ New York mailbox will be created in American datacenter and London mailbox will be created in European datacenter
d\ All mailboxes are created in American Datacenter
gfernandez
Another question was:
Q. What steps are needed to disable app passwords for non-browser clients
Correct answer is
1- In office 365 Admin Center, select Active users node under users node and then click set up next
2- On multifactor authentication page click service settings
3- On service settings choose disallow
https://books.google.es/books?id=za_fCQAAQBAJ&pg=PT162&lpg=PT162&dq=disable+app+passwords+office+365+70+346&source=bl&ots=D_EHTyw5Gy&sig=Kb9yU0Etxqw1UKrUUzim65kHUuE&hl=es&sa=X&ved=0ahUKEwjWo9e6revLAhXCDxoKHR34BeQQ6AEIHDAA#v=onepage&q=disable app passwords office 365 70 346&f=false
Nilofar Nisha
Hello Friends,
Could someone please share the latest dumps for exams 70-346 and 70-347 papers and also let us know if Microsoft provides second shot for the exams now
diego
Thanks a lot Naruc.
god bles u my friend
diego
I got the exam in a couple of days, i inform you soon my friend.
diego
@ Naruc, I passed the exam but there are few wroing answers i think. My score was 7XX
coddeest
Thanks Naruc for the files and thanks gfernandez for the two new questions.
What did you answer by this question?
Answer B is so far I know not possible and answer D I can't imagine because they have datacenters around the world:
http://o365datacentermap.azurewebsites.net/
I guess answer A or C.
coddeest
Thanks naruc for the exam pdf/vce and thanks gfernandez for the 2 new questions.
What did you answer on this question or does someone knows the answer?
Answer B is not possible so far I know and answer D I can't imagine, because they have datacenters around the world:
I guess Answer A or C.
spudgey
Just took the exam and passed with 9xx. All questions in the exam were in the dump.
Thanks Naruc!
Naruc
Congratz. I am glad, I was able to help
diego
Hi Naruc, can you also help me with the another exam of office 365. Exam number 70-347?
tjoep
Passed with studying this file. From the 57 questions, there were 6 that I haven't seen. And 3 that were a little different in their answer.
The new ones:
One about syncing 0365 with local forest. (answers were focussed on installing aad sync or dirsync on both locations)
One was adding details of the dns properties for s4b on an image (see page 49 & 50 of the exam ref)
One was the one mentioned here above: on what datacenter will the new mailbox be created, london of USA.
One was were you had to choose three different roles for the correct azure rights management task.
Hope this helps.
