220-1002 Exam Dumps Replaces 220-902 Test
wirygnrhd
CompTIA A+ 220-902 exam will be retired on Jul.31, 2019, the new replacement test is 220-1002. To earn CompTIA A+ certification, you need to take 220-1001 and 220-1002 exams after Jul.31, 2019. Share some CompTIA A+ 220-1002 exam dumps questions below.
A technician arrives on site to find that two users who have the same model on Android smartphone are having the same issue with a specific application. Whenever they attempt to launch the application, it fails and gives an error message.Which of the following should the technician do FIRST?
A. Reinstall the application
B. Roll back the application to the earlier version
C. Clear the application cache
D. Update the OS of the smartphones
A technician is working on a Windows 10 PC that is running slowly.Which of the following commands should the technician use to correct this issue? (Select two.)
A. dir
B. chdsk
C. dism
D. ipconfig
E. format
F. diskpart
An administrator is setting up a Windows terminal server.Which of the following settings should the administrator modify to increase server security? (Select two.)
A. Change the default access port
B. Enforce password complexity
C. Put the terminal server into the router’s DMZ
D. Disable logon time restrictions
E. Block all unused ports on the LAN smart switch
F. Use the local client certificate for server authentication
Answer: CE
Get more CompTIA A+ 220-1002 exam dumps questions here.
Kimberley Hinds
TheExamCerts is the best site which provides you with the necessary CompTIA 220-1002 questions that will help you to get the 220-1002 CompTIA A+ Core 2 exam on the first attempt. The latest questions can be found here and that is the reason why this is the one that you need to use and I can tell you that there is no reason for you to fail when you will have valid CompTIA 220-1002 braindumps from TheExamCerts. They have the guarantee that the CompTIA 220-1002 questions that they have will be the ones that will make you pass your 220-1002 exam in the very first go. You must try our CompTIA 220-1002 free demo befor your successive purchase. Follow this link and get 20% discount offer [Limited Time]:
