[2019-July-Updated] Exam AZ-103 VCE Dumps and AZ-103 PDF Dumps
gankganka
Get the latest AZ-103 Dumps shared by Realdumpspdf for Helping Passing AZ-103 Exam! We now offer the newest AZ-103 VCE dumps and AZ-103 PDF dumps:
NEW QUESTION 22
You plan to automate the deployment of a virtual machine scale set that uses the Windows Server 2016 Datacenter image. You need to ensure that when the scale set virtual machines are provisioned, they have web server components installed. Which two actions should you perform? (Each correct answer presents part of the solution. Choose two.)
A. Modify the extensionProfile section of the Azure Resource Manager template.
B. Create a new virtual machine scale set in the Azure portal.
C. Create an Azure policy.
D. Create an automation account.
E. Upload a configuration script.
Virtual Machine Scale Sets can be used with the Azure Desired State Configuration (DSC) extension handler. Virtual machine scale sets provide a way to deploy and manage large numbers of virtual machines, and can elastically scale in and out in response to load. DSC is used to configure the VMs as they come online so they are running the production software.
https://docs.microsoft.com/en-us/azure/virtual-machine-scale-sets/virtual-machine-scale-sets-dsc
NEW QUESTION 23
Your company has an Azure subscription named Subscription1. The company also has two on-premises servers named Server1 and Server2 that run Windows Server 2016. Server1 is configured as a DNS server that has a primary DNS zone named adatum.com. Adatum.com contains 1,000 DNS records. You manage Server1 and Subscription1 from Server2. Server2 has the following tools installed:
– The DNS Manager console
– Azure PowerShell
– Azure CLI 2.0
You need to move the adatum.com zone to Subscription1. The solution must minimize administrative effort. What should you use?
A. The Azure PowerShell
B. The Azure CLI
C. The Azure Portal
D. The DNS Manager Console
Azure DNS supports importing and exporting zone files by using the Azure command-line interface (CLI). Zone file import is not currently supported via Azure PowerShell or the Azure portal.
https://docs.microsoft.com/en-us/azure/dns/dns-import-export
NEW QUESTION 24
You have an Azure Active Directory (Azure AD) tenant named contosocloud.onmicrosoft.com. Your company has a public DNS zone for contoso.com. You add contoso.com as a custom domain name to Azure AD. You need to ensure that Azure can verify the domain name. Which type of DNS record should you create?
A. RRSIG
B. PTR
C. DNSKEY
D. TXT
Create the TXT record. App Services uses this record only at configuration time to verify that you own the custom domain. You can delete this TXT record after your custom domain is validated and configured in App Service.
https://docs.microsoft.com/en-us/azure/dns/dns-web-sites-custom-domain
NEW QUESTION 25
You have an Azure virtual machine named VM1. VM1 was deployed by using a custom Azure Resource Manager template named ARM1.json. You receive a notification that VM1 will be affected by maintenance. You need to move VM1 to a different host immediately.
Solution: Solution: From the Overview blade, you move the virtual machine to a different subscription.
You would need to Redeploy the VM.
https://docs.microsoft.com/en-us/azure/virtual-machines/troubleshooting/redeploy-to-new-node-windows
NEW QUESTION 26
You have a resource group named RG1. RG1 contains an Azure Storage account named storageaccount1 and a virtual machine named VM1 that runs Windows Server 2016. Storageaccount1 contains the disk files for VM1. You apply a ReadOnly lock to RG1. What can you do from the Azure portal?
A. Generate an automation script for RG1.
B. View the keys of storageaccount1.
C. Upload a blob to storageaccount1.
D. Start VM1.
ReadOnly means authorized users can read a resource, but they can’t delete or update the resource. Applying this lock is similar to restricting all authorized users to the permissions granted by the Reader role.
https://docs.microsoft.com/en-us/azure/azure-resource-manager/resource-group-lock-resources
Get the newest AZ-103 PDF dumps here: https://www.realdumpspdf.com/exam/az-103-dumps-pdf/
Edward Marrero
TheExamCerts is the best site which provides you with the necessary Microsoft AZ-103 questions that will help you to get the AZ-103 Microsoft exam on the first attempt. The latest questions can be found here and that is the reason why this is the one that you need to use and I can tell you that there is no reason for you to fail when you will have valid Microsoft AZ-103 braindumps from TheExamCerts. They have the guarantee that the Microsoft AZ-103 questions that they have will be the ones that will make you pass your AZ-103 exam in the very first go. You must try our Microsoft AZ-103 free demo befor your successive purchase. Follow this link and get 20% discount offer [Limited Time]:
